Aktuelle Zeit: Mo 17. Jun 2019, 11:45
Ein neues Thema erstellen  Auf das Thema antworten  [ 8 Beiträge ]
BeitragVerfasst: So 14. Jan 2018, 01:02
I've owned this bike now for a couple of months and slowly been modding it and adding accessories to it for protection and reliability.
If anyone knows how to read the hour meter please let me know. :oops:
Firstly an Australian built bash plate was added.
The wiring was tidied up behind the headlight to prevent the wiring loom from bending on the left hand side of the head stem. I believe the wiring will break here if left the way it comes from the factory.
The clutch starter switch was also bypassed.
Hand and lever protection added (called bark busters in Australia).
The horn was removed from in front of the right hand side radiator and relocated under the fuel tank on the left hand side. The bracket was modified to allow this.
The radiator guards were very loose when fitted. These were modified by adding small lengths of tube pressed over the two locating bosses.
BeitragVerfasst: So 14. Jan 2018, 10:06
mrsdnf hat geschrieben:
At first welcome on board. And second, do not care about the hour meter at the Display. It counts all the Time. My dealer told me that he can read the real hours when he put on the Diagnostiktool.
I hope you understand what i am meening. It is a long time ago when i wrote english.
BeitragVerfasst: So 14. Jan 2018, 20:58
cp2675 hat geschrieben:
Thanks cp2675 for the explanation on the hour meter. That would make sense.
I'm not sure how the translation works when I post up and you read it as Google translates most of the page for me.
BeitragVerfasst: Mo 28. Mai 2018, 11:34
Just an update on a few more mods. The original turn signal and number plate rear bracket was removed. Some cheap led turn signals were purchased from Ebay and fitted to these made up brackets.
The front turn signals were removed from the top triple clamp bolt as the brackets for them were tearing the tie downs when I was transporting the bike in my trailer. They were remounted where the original Husqvarna indicators were mounted. They just hit the radiator shrouds but I dont see this causing a problem.
A boss was machined up to fit the head stem for the breather hose to sit in.
BeitragVerfasst: Do 14. Mär 2019, 19:12
Hallo an die Runde,
ich habe mir ein Akrap nachbau aus E**ay gekauft für 50 € und Mappe von Arrow draufgespielt.
Das Ganze Mottorad ist insg, 7 Kg leichter und geht´s wie feuer, der Soud ist auch mega.
Ich wohne in Auetal ind besitze das Datenkabel ...
Dateianhang:
20190111_164037.jpg [ 220.17 KiB | 1263 mal betrachtet ]
Dateianhang:
20190111_162256__1.jpg [ 199.24 KiB | 1263 mal betrachtet ]
BeitragVerfasst: Sa 16. Mär 2019, 15:11
ada0607 hat geschrieben:
Hallo an die Runde,
Nice! Woher ist denn der Krümmer? ...und woher hast du die Mappings und das Datenkabel? Dachte bis jetzt, dass das nur ein offizieller Händler bekommt.
BeitragVerfasst: Di 19. Mär 2019, 10:06
Looks good ada0607. Like bndr I'd like to know where you got the cable and update info.
BeitragVerfasst: Do 18. Apr 2019, 21:45
bndr hat geschrieben:
Hallo an die Runde,
Krümmer selbst gemacht, kann ich gerne helfen, mit Mappen ebendso.
Mitglieder in diesem Forum: 0 Mitglieder und 2 Gäste
